Ignition Probs
Old Dec 9, 2004 | 12:06 PM
Cliffdog's Avatar
Cliffdog
Ignition Probs
Guys Im Havin The Wierd Ignition Problems...ill Start "ole Girl" And Runs Ok Till 3rd Gear Then I Get A Wierd Miss...ok Now The Plugs Wires Cap Rotor Coil Are All New..ok Now When Its Missin If I Down Shift To 2nd And Whack The Pedal Run Ole Girl To About 5grand On The Tach..it All Goes Away And Runs Great....any Ideas???
Old Dec 14, 2004 | 01:27 PM
jwtaylor's Avatar
jwtaylor
Take it to autozone and have them pull the codes for you, it could be emissons equipment related. Codes don't always show up in the form of a check engine light.
What you have described could be many things, faulty fuel pump, clogged fuel filter, faulty ignition module...good luck
