mileage?
Old Dec 14, 2004 | 09:52 AM
66GTO's Avatar
66GTO
mileage?
I have a 2004 Lariat Crew Cab Diesel with 2500 miles. In all kinds of driving I have racked up 3000 miles and the fuel economy guage tells me I am averaging 12.8 mpg. Is this what I should expect or does it improve slightly as the miles get added on? I have the 4.10 rear end and automatic tranny.
Old Dec 14, 2004 | 11:44 AM
77hiboyboy's Avatar
77hiboyboy
tall gears, auto trans, how fast are you running it?? These things do best under the 2k rpm range.
Old Dec 14, 2004 | 12:52 PM
66GTO's Avatar
66GTO
The 12.8 mpg is actually from when the truck was brand new. Since I cant figure out how to re-set the guage the mileage is hwy pulling a trailer for about 2000 miles and 1000 miles of around town. Speed while trailering was about 65 and around town is crawling.
I am not expecting Honda Civic mileage, and this 12.8 mpg is certainly better than my old 1995 Dodge with the 360 engine (8mpg). So I am not disappointed in 12.8, but was wondering what others are getting.
Old Dec 14, 2004 | 03:30 PM
RodbusterGS's Avatar
RodbusterGS
To reset your MPG gauge, hold both buttons on the overhead console down simultaneously for a few seconds. The gauge will reset
Old Dec 14, 2004 | 10:06 PM
66GTO's Avatar
66GTO
Hey, thanks!
Old Dec 15, 2004 | 10:47 AM
Motown Fire's Avatar
Motown Fire
I get about 12.5 - 13 mpg around town and 17 mpg highway.
Old Dec 15, 2004 | 12:03 PM
Daryl Hunter's Avatar
Daryl Hunter
Originally Posted by 66GTO
Hey, thanks!
By the way,
WELCOME to the site, please read the Guidelines… Check out the list of forums and make sure you read the headings and Read First: notices in each forum.
Be sure to check out the 6.0 Bible…..great reading
http://dan.prxy.org/Truck/6L_bible_html/html/TOC.html
http://www.backglass.org/duncan/ps60_manual/
…. In the upper right hand corner of your screen check this out PARTS SHOP for all your “trucking” needs
Must read
http://www.clubfte.com/users/monsta/SuperDutyFAQ.html
https://www.ford-trucks.com/forums/showthread.php?t=303583
Enjoy FTE
Old Dec 15, 2004 | 01:54 PM
jackofalltrades's Avatar
jackofalltrades
66GTO,
You should experience a bit better mileage in the miles to come as the 6.0 breaks in. But as 77Highboy points out, the 4.10:1 gears are going to raise your rpm on the freeway. As a comparison, my 6.0 with just a thousand more miles on it, with 3.73:1 gears and the 6spd standard transmision, is averaging 17mpg in town/mix county roads with my best of 19.5mpg on the freeway averaging 70mph. Last time I towed a 5000 pound trailer over the pass, it got 15mpg.
Many people with the computer/runtime display for mileage call it a LieOmeter. Best to do the math when wanting good figures for mileage. I keep a log book for every fill up and maintenance practice on the truck. I just keep it in the sorry excuse for a console, and am religious at keeping it up to date.
Old Dec 15, 2004 | 01:55 PM
Hot Spot's Avatar
Hot Spot
14 city, 14 towing 23 foot center console boat, 22 highway.
I reset my computer and odometer after every fill up.
Old Dec 15, 2004 | 02:04 PM
olfordsnstone's Avatar
olfordsnstone
I dont know how you can accurately calculate your mileage when there is such a variance from one pump to another. I have a friend who also has a 6.0 SD that says that he added an additional 5 gallons once to his tank after the pump shut off. Personally, I am having difficulty in getting consistant calculations. Anyone have a more consistant method?
Old Dec 15, 2004 | 02:14 PM
Daryl Hunter
We fill up till the pump clicks off, then slowly add more fuel until it is at the filler neck - about 5 gallons most of the time.
The important thing is to be consistent in your method.
Old Dec 15, 2004 | 02:15 PM
olfordsnstone
Patience Patience eh? Where I get fuel, I get lots of sudds.
Old Dec 15, 2004 | 02:27 PM
rocknut's Avatar
rocknut
I never can get that much more fuel after the pump clicks off. Maybe 1-gallon if even that.
Old Dec 15, 2004 | 03:14 PM
jackofalltrades
Most of the time I drive until the low fuel light comes on. I know then that I should be able to get 35+- gallons in. I consistently pump until it's full every time. And over time if I've got one trip/calculation that's a bit off, high or low, from the other numbers then I throw that value out. That's a realistic approach to calculating the most consistent average of "average fuel consumption" per tank. With that as a base, I trust that the mileage reported by my odometer, derived from drivetrain revolutions through stock sized tires, is correct to within .1%. (Close enough for Government work!) When I calculate, I round the final value to the nearest whole number. High or low. Not rocket science, just calculating fuel economy.
Remember, you can skew statistics, but the numbers don't lie.
If the fuel foams while filling. I pump slower. If it only foams at one pump/service station. I use a different pump/service station from then on. It's amazing what little thing it takes to get me to not patron a particular business.
Old Dec 15, 2004 | 04:21 PM
66GTO's Avatar
66GTO
Thanks guys for the input. I mentioned that during 2000 of the 3500 miles or so I was pulling a trailer. What I didnt mention was that it was a four horse gooseneck. Estimated weight with horses and stuff was probably 12,000+ pounds.
I love this truck. I do have another question though. How long does it take to get used to the TURNING RADIUS? Or lack there of. Is it because it is a dually or because it is three feet longer than my Dodge? Wow, I dont know how many times I have tried a U turn and it turns into a three point turn with people giving me the evil eye.
I do know when I travel on the two lane country roads around here people give me a wide berth when they see me approaching.
