Intermitant no start
Old Dec 14, 2004 | 09:09 AM
jesus_man's Avatar
jesus_man
My '02 explorer 4.6L has recently given my wife trouble when starting. The last time it did it was when it set for 2-1/2 days, then it did it again this morning only after setting for 16 hrs. It won't start unless you give it some gas. (Which I didn't think would work because it's all electronic now). I will pull the codes tonight and see if there is anything besides a bad sensor in the emmisions system.
Thanks for your help!
jman
Old Dec 14, 2004 | 10:32 AM
87 XLT's Avatar
87 XLT
Take a look at "read first IAC repair help" at the top of the forum.
Old Dec 14, 2004 | 10:57 AM
jesus_man's Avatar
jesus_man
once mine starts, it's good to go, or at least has been. I found the post I had earlier about my emmisions trouble:https://www.ford-trucks.com/forums/s...d.php?t=296655. I'll be digging into it tonight. Thanks for your help!
jman
Old Dec 14, 2004 | 06:39 PM
87 XLT's Avatar
87 XLT
Have you tried cycling the key on for 2 seconds then off. Do that 6 times & see how it starts.
Could be a bad coolant temp sensor, which should show up when you pull the codes.
Good luck with it.
Old Dec 16, 2004 | 09:14 AM
jesus_man's Avatar
jesus_man
Hmm, that's what my cousin and I were thinking. The code I got was P0401 Exhaust Gas Recirculation flow Insuff Detected. However, that Check Engine light has been on for some time so I don't know what code this is related to. Does anyone know where I could fine ohm readings for this to test if it's bad?
What's the logic behind cycling the ignition? Does it reset the computer? Thanks!
jman
Old Dec 16, 2004 | 12:25 PM
87 XLT's Avatar
87 XLT
Try doing a forum search on P0401, you should come up with some good info on this. As I recall from other posts a bad DPFE sensor is a common cause for the P0401, it monitors the EGR flow. Another possibility is a disconnected vacuum hose at the EGR solenoid or clogged EGR ports. If theres a disconnected vacuum hose it might be the reason for the hard starts?
If the fuel pump is weak, cycling the key will build fuel pressure.
Since it starts when you open the throttle , you might also want to remove the IAC & see if it's clogged up.
Old Jan 3, 2005 | 09:16 AM
jesus_man's Avatar
jesus_man
I replaced the DPFE sensor and while it seems to have solved the CEL light, it was hard to start this morning. Haven't checked into the coolant temp sensor yet. I hope this isn't the beginning of a long string of problems...
jman
mhancock2
Apr 14, 2011 07:02 AM
bamaf150
16
Apr 30, 2010 11:56 AM
Action4478
20
Jan 29, 2010 10:50 AM
JoeSwing78
17
Jun 2, 2008 06:09 AM
dtong_ck
Aerostar
Dec 16, 2001 09:16 PM
