Oil
Old Feb 22, 2000 | 07:51 PM
CantDrive55's Avatar
CantDrive55
Oil
Old Mar 6, 2001 | 07:37 PM
matthart454's Avatar
matthart454
Oil
What kind of Oil and Filters do you guys like? I heard that 10-40 isnt any good. So whats best for a higher mileage engine?
Old Mar 7, 2001 | 07:15 AM
lordconqueror's Avatar
lordconqueror
Oil
actually for a high mileage engine, 10-40 (even 10-30) might be better than a lower weight oil...depends on the amount of sludge built up and the condition of your seals. lower weight oil can get around the build-up and/or worn seals and cause leaks. definitely don't start using synthetic now (same problems as lower weight oil). as for filters, puralator filters rank high on filtration for conventional oils (fyi-motorcraft filters are puralators) stay away from frams!! hope this helps
lc
