timing problems
Old Dec 14, 2004 | 03:45 AM
carusdr's Avatar
carusdr
timing problems
Just rebuilt a 302, new Comp cam (252h-10), Performer intake manifold, Eldenbroc 600 carb, 289 heads have adjustable rockers, and running 165-170 compression all cyl.
Problem: When set to recomended timing (8 deg. BTDC) Spark nock. Sounds like the whole valve timing is out. No power, low vacume. Idles great.
Things that I have tryed: Reset lash Hydl. lifters, center line of cam 106, pulled intake thought maybe a leak under one of the runners, checked vacume advance on Dis. Points set right, leaned out carb (jets and rods). The only other thing I can think of is maybe the valcume advance is advancing to much, it is the only thing on the motor thatis not new.
I am in need of new ideals or fixes.
Thanks
Old Dec 14, 2004 | 10:51 AM
smoke n tires's Avatar
smoke n tires
i answered in the other forum.......
