1978 - 1996 Big Bronco
auto floor shift
Old Dec 13, 2004 | 10:16 PM
johnned's Avatar
johnned
auto floor shift
I have a used automatic floor shifter with the cable given to me . But park is towards the back of the transmission. I don't know how to make this work. Do I need some sort of bracket or will I have to remove the valve body and turn the linkage over. Help would be greatly appreciated. Thanks fellas.
(C6 trans)
Old Dec 13, 2004 | 10:28 PM
Zane M's Avatar
Zane M
What type of shifter is it? If a B&M. you can download instructions from the B&M website.
Unless you have a reverse valvebody/shift pattern, the most rearward position should be low, not park.
Old Dec 14, 2004 | 09:28 PM
johnned's Avatar
johnned
floor ****er
the (shift)arm goes up, not down, low is forword. I got A cable long enough to go to the front an point towords the back. thanks anyway (no rev valebody)
Old Dec 14, 2004 | 10:17 PM
greystreak92's Avatar
greystreak92
You would have to create an extra arm at the linkage to make another pivot point which would invert the movement from the shift cable.
Old Dec 15, 2004 | 11:13 AM
johnned's Avatar
johnned
thank, you guys alway help. Ill be back
djm1204
Jan 20, 2015 12:12 PM
Marks9mm
Jul 4, 2014 07:40 PM
ggadwa
6.7L Power Stroke Diesel
Jan 6, 2013 06:54 AM
rschwab
May 12, 2004 10:38 AM
DCS 03
Oct 4, 2002 12:27 AM
