Clutch Question
Old Dec 13, 2004 | 07:31 PM
MasterTrim's Avatar
MasterTrim
Clutch Question
I have an 87 6.9 w/5speed. When I bought it I had to put my foot though the firewall to get it into gear so, I read alot of old posts and talked to a friend who worked at FORD, about this problem. I pulled out the fork and inspected it, it looked fine, no wear. I did not let the plunger on the slave come out but, now I cannot get it into 1st or reverse even after bleeding it. I have to pump it like 10 times for it to barely get into gear. I instpected firewall for cracks and there is none. Looked at the pedal bushings and they look fine too. When I talked to my friend he told me that these things have been a problem bleeding out the air since NEW! That somehow air bubbles get trapped and the fluid just flows right by. Is this true? There has to be a way to fix this... Any help is appreciated!
Ken
Old Dec 13, 2004 | 08:44 PM
shadowcaster's Avatar
shadowcaster
luk conversion kit,,be the best upgrade you will ever do for your clutch!!
Old Dec 14, 2004 | 08:15 PM
MasterTrim's Avatar
MasterTrim
Found problem... I adjusted eyelit bolt from linkage to master. works great!!!
