Fan clutch problem ???
Old Dec 13, 2004 | 03:38 PM
jpm2591's Avatar
jpm2591
I'm wondering if my fan clutch is working properly. It's cold here about 38. I just replaced my fuel filter and started the truck to check for leakage. At idle I noticed the fan moving very fast. I shut the truck down and turned the fan by hand and it was very stiff. I then checked the clutch fan on my 89 bronco and it turned freely.
Any help here would be very appreciated!
Old Dec 13, 2004 | 03:56 PM
kilapapipa's Avatar
kilapapipa
Were either of the engines you checked just turned off at operating temp. That is when it should move freely.
Old Dec 14, 2004 | 08:20 AM
jpm2591's Avatar
jpm2591
No they were both cold. I didn't check it at operating temp.
Old Dec 14, 2004 | 08:36 AM
kilapapipa's Avatar
kilapapipa
Get your truck to operating temp and then shut it down and check it. It should move freely then. I would think the Bronco clutch fan is not operating right. I had that happen on an 85' T-bird and had to replace it. It was overheating in the summer.
