Vibration
Old Oct 27, 2004 | 07:56 AM
JMACC's Avatar
JMACC
Vibration
Just a quick question-
I have this vibration between 45-55mph at the gas(diesel) pedal and seems to be right under the floor as well? I am taking it to see how the alignment is but is there anyone who has had the same symptoms? Thanks in advance.
JMACC
Old Nov 16, 2004 | 11:41 AM
bronco252's Avatar
bronco252
I had a vibration between 70-78. It was the rear universal joint.
Old Dec 14, 2004 | 07:40 AM
bronco252's Avatar
bronco252
JMACC did you ever find out what that vibration was?
Old Dec 14, 2004 | 08:48 AM
JMACC's Avatar
JMACC
Actually- no I still haven't found the culprit. I am assuming its a u-joint,I had the front end checked and its right on the money. Next step could be to have the wheels and tires rebalanced? But with the christmas season upon us time is limited, so after the holiday u-joints will be the order of the day(all of them).
With 134,000 miles its probably a good idea.Thanks for the reply and I'll post when the joints are done to see if it makes a diff.
JMACC
Old Dec 14, 2004 | 10:46 AM
slc10844's Avatar
slc10844
What year and model?
Old Dec 14, 2004 | 10:54 AM
JMACC's Avatar
JMACC
Its a 2000 CC Lariat 4x4 with an 8' bed and of course a PSD.
Old Dec 14, 2004 | 11:24 AM
Silverrv's Avatar
Silverrv
Unhappy Vibration,,, me too.
I have a 2002 CC 8' bed PS SD and I have been fighting a vibration for about the last 30K miles. It has 70K now and I can't find it. The vibration is in the foot pedal and also in the steering wheel and seat.. I have done the wheel thing and the dealer even changed out the torque convertor. If you come up with any thing I would be interested.
Old Dec 14, 2004 | 11:26 AM
slc10844's Avatar
slc10844
FYI - This may apply to your vibration.
TSB 04-22-7
FORD: 1999-2005 F-Super Duty
ISSUE:
Some 1999-2005 Super Duty F-Series may exhibit excessive drive-away shudder or vibration, under moderate to heavy acceleration from a stop. This may be due to driveline angle.
ACTION:
Shim the center carrier bracket downward to correct the condition. Refer to the following Service Procedure.
SERVICE PROCEDURE
When shimming the center carrier bracket, a maximum of three (3) 1/4 inch shims may be used (EOTZ-4A209-A). When refastening the carrier bracket use bolt (56564-S2). A 7/16 x 14 grade 5 bolt may be substituted providing that it extends at least 3 threads past the nut. Use Motorcraft Threadlock 262 (TA-26), and torque bolts to 46 lb-ft (62 N-m).
NOTE: IF THE VEHICLE IS NORMALLY LOADED, ROAD TESTS WILL NEED TO BE PERFORMED WITH THE VEHICLE LOADED.
Before beginning the repair, road test the vehicle to gain a feel for the harshness of the shudder/vibration.
Install one (1) shim, (DO NOT use Threadlock on the bolts at this point), re-road test vehicle.
If condition is corrected, apply Threadlock and torque bolts as directed above. Return the vehicle to the customer.
If condition is not corrected, re-perform Step 2 (to a maximum of three (3) shims) and reevaluate vehicle.
NOTE: IF THE CONDITION IS STILL NOT CORRECTED AFTER INSTALLING A MAXIMUM OF THREE (3) SHIMS, REFER TO WORKSHOP MANUAL SECTION 205-00 FOR FURTHER DIAGNOSTICS.
PART NUMBER PART NAME
EOTZ-4A209-A Shim
56564-S2 Bolt
TA-26 Motorcraft Threadlock 262
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
OPERATION DESCRIPTION TIME
042207A Road Test To Verify Concern, Install One Shim, And Road Test To Verify Repair (Includes Time To Raise Vehicle And Install Threadlock) 1.2 Hrs.
042207B Road Test To Verify Concern, Install One Shim, And Road Test To Verify Repair Condition Still Exists, Install A Second Shim And Road Test (Includes Time To Raise Vehicle And Install Threadlock) 1.7 Hrs.
042207C Road Test To Verify Concern, Install One Shim, And Road Test To Verify Repair, Install A Second Shim And Road Test Condition Still Exists, Install A Third Shim And Road Test (Includes Time To Raise Vehicle And Install Threadlock) 2.2 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
4A209 42
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2004 Ford Motor Company
JMACC
Sep 24, 2005 09:22 PM
JMACC
Jul 6, 2005 04:34 PM
JMACC
Mar 4, 2005 02:38 PM
JMACC
Jan 13, 2005 09:09 AM
JMACC
Dec 30, 2004 12:55 PM
