Stalled
Old Dec 13, 2004 | 12:22 PM
willson_man's Avatar
willson_man
Question Stalled
My 95 f-150 stalled out of the blue last night, and wont start.I have gas, and spark. Any ideas?
Old Dec 13, 2004 | 12:48 PM
dkaska77's Avatar
dkaska77
Details?
Under accelration, carb, efi.
Turn the key can you hear the pump? Can you hear relay before pump?
TPS is probably your problem. But without the simple details we have to guess what you have.
Old Dec 13, 2004 | 03:15 PM
willson_man
about 2:00 am, I started my truck, drove 2 blocks, pulled in my driveway, put it in park, and it stalled.I have fuel to the motor,iI can hear the fuel pump, and I do have an orange spark at the coil, and the plug.
Old Dec 13, 2004 | 03:19 PM
sandrat's Avatar
sandrat
OK, you hear the fuel pump run, but do you have pressure at the rail? And I'm not too sure about that spark either.
Old Dec 13, 2004 | 04:42 PM
willson_man
yes, i have pressure at the rail, im gonna try changing the coil.If that doesnt work,I dont know what to do next.I just tuned it up last spring, so I know plugs, wires ect. are good.
Old Dec 14, 2004 | 08:31 AM
sandrat's Avatar
sandrat
Be careful assuming, man. I've gotten junk parts many a time. Make sure you've got a good strong spark at every plug, that should eliminate the ignition sys. and therefore an expensive coil. If you've got spark and pressure at the rail, I'd check your injectors next. Are they getting a signal or not?
Old Dec 14, 2004 | 12:41 PM
willson_man
FYI I changed the coil, and it started right up. thannnks .
Old Dec 14, 2004 | 12:45 PM
willson_man
Thumbs up
I see your piont on changing parts, but a 13.00 coil was cheaper then a 50.00 set of noid lights.it was a good educated guess
