Sponsored by: Auxito
odometer on and off
Old Dec 13, 2004 | 10:42 AM
balingwire's Avatar
balingwire
odometer on and off
The odometer on my '99 F-150 Off-Road goes on and off without any pattern. If the truck sits for a while, it does seem to always come on when the truck is started. Then it may stay on for a while, then go out for a while, then come back on. Almost acts like a loose connection. Has anyone experienced this, and if so, how did you fix it. Thanks.
Old Dec 13, 2004 | 03:29 PM
KYFord's Avatar
KYFord
I have the same issue with my 99 F150 5.4L 4x4. Curious to see how to fix.
Old Dec 13, 2004 | 04:10 PM
firedog4689's Avatar
firedog4689
This may not help, but my father had the same problem with a Toyota and the problem turned out to be in the cruise control. Hope this helps.
Old Dec 13, 2004 | 05:13 PM
triton_2002's Avatar
triton_2002
This may be the solution:
https://www.ford-trucks.com/forums/s...d.php?t=196821
Old Dec 13, 2004 | 05:49 PM
HOLESHOT1's Avatar
HOLESHOT1
I had the same thing going on with my '99 f150 xlt for about 2 years or so. It was a simple fix, though. I went out and traded it in for an '04 F150 FX4. That seemed to do the trick.
