Sponsored by: Auxito
power door locks
Old Dec 9, 2004 | 06:54 PM
DHinSC's Avatar
DHinSC
power door locks
I bought a used 2000 f150. Both doors will not open from the remote or pushbutton most of the time. Every once in a while they work fine. both doors lock remotely just fine. The door locks attempt to unlock but only move part way. Could it be that both solenoids are weak or is there a common connection that may be loose?
Old Dec 10, 2004 | 10:22 AM
415dave's Avatar
415dave
It's a common problem with these trucks. The door lock actuators from the factory were apparently junk. You might luck out and get away with cleaning and lubing, but if you're like me you'll be replacing them. I've found them online for about $42.00 each. The price isn't too bad, but from what I've been told they're a pain to remove and re-install. If you're tempted to go the salvage yard direction, don't. You'll end up with the same problem down the road and have to do it all over again. Hope this helps.
Old Dec 11, 2004 | 06:30 PM
DHinSC's Avatar
DHinSC
Thanks!! I guess I'll begin by pulling the door panels to see what shape they are in.
Old Dec 12, 2004 | 07:34 PM
low's Avatar
low
Don't bother pondering wether they are good or not, you need two door lock actuators.
Old Dec 13, 2004 | 07:37 PM
AzBlueWolf's Avatar
AzBlueWolf
you could just walk around to the other side and use the key...
crazy idea... I know
Mark
_______________________________________
01 F150 Supercab Flareside XLT 4x2 5.4L Auto
Deep Wedgewood Metallic and Silver L/S 3.55
Fabtech Lift 285/75/R16 DominatorSport A/T's
