truck weight
Old Dec 13, 2004 | 07:26 AM
towtruck's Avatar
towtruck
truck weight
How much do these trucks weigh? I have a 77 F150 4x4 with a 400 and the last time it was on a scale it was around 5300 pounds. (Hauled some trash). A guy I work with said I payed to much for the dump cause my truck weighs around 7000 pounds and I should have only payed for 500 pounds and not a ton.
Old Dec 13, 2004 | 07:55 AM
mark a.'s Avatar
mark a.
5300 sounds a little too heavy for a stock 1/2 ton 4x4. I'd bet more like 5000 max. Scales will vary from place to place if there not certified.
Old Dec 13, 2004 | 01:22 PM
ivanribic's Avatar
ivanribic
My truck weighs 6900. Supercab F250 4x4 with a 460. About 500 pounds of that is tire. I don't think your truck weighs 7K. It's always hard to say but I'd agree with Mark that you're probably rolling right around 5K.
Old Dec 13, 2004 | 07:10 PM
teds74ford's Avatar
teds74ford
My truck weighs 5300 with me and a buddy in it. I would assume it weighs just under 5K, so you probably aren't too far off. The only thing different between mine and yours is a dana 60 rear. The rest should be about the same.
Old Dec 13, 2004 | 10:24 PM
towtruck's Avatar
towtruck
Thanks, I thought 5000ish was right.
Old Dec 14, 2004 | 12:01 AM
longview1's Avatar
longview1
Banned
My 78 1/2 with steel box,390 , 1/4 tank of fuel, Me, tool box and 40" tires wiehgs about 3010 Kg, which according to my calculator is about 6622lbs.
Old Dec 14, 2004 | 01:53 AM
ford390gashog's Avatar
ford390gashog
your friend was probably reffering to the gvwr on the truck people think that the truck weighs that much when that is just the capacity
