rearend
Old Dec 13, 2004 | 12:50 AM
trkdrvr's Avatar
trkdrvr
Question rearend
ok another silly question. what does the 3.73 rearend mean? what is that made for towing or hotroding? the truck had a camper on it before i bought it. thanks alot anyone.
Old Dec 13, 2004 | 12:59 AM
mulletbob69390's Avatar
mulletbob69390
not the best for highway, had a 70 f250 2x4 worked good for me
Old Dec 13, 2004 | 01:02 AM
trkdrvr's Avatar
trkdrvr
so does that mean it needs to be changed ? i have a new 352 in it.
Old Dec 13, 2004 | 05:54 AM
jowilker's Avatar
jowilker
Gil, It is the engine/rear axle turning ratio.
Your engine is turning 3.73 times to your tires one.
Someone else can splain the finer points.
John
Old Dec 13, 2004 | 12:29 PM
Freightrain's Avatar
Freightrain
The "higher" the number, the more revolutions the engine turns to make the vehicle go forward at the same speed(mph).
Your 3.73 is a good gear for mild pulling, a bit steep for highway cruising/good gas mileage. The lowest ratio is 3.25, the highest was 4.11 from factory(some even had 4.56).
Depending on how tall your tires out back are will also affect that ratio. IE: your 3.73's with 30" tire will turn "X" number of revolutions. IF you put a 25" tire on it, it will turn 17% FASTER than "X" since the tire is shorter. In reverse of that if you put a 35" tire it will turn 17% SLOWER than "X" because the tire is taller.
Hope this helps.
Old Dec 14, 2004 | 12:19 AM
trkdrvr's Avatar
trkdrvr
Thumbs up reply
ok i get it now im a newbe to this just wanting to know about my truck. i have 16 inch tires on the rear. dont do much freeway driving. the truck had a camper on it thet is maby why it has a gear like that. thanks for the help you people give me. it will help me alot. if you dont mind what kind of gears should i buy to make the 352 do good burouts if needed. i know i might buy a holley carb soon. that will do some of the trick.
Old Dec 14, 2004 | 01:01 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
rear gears and trans
It's 37 years old, don't go and tear it up. Your a little short on torque with a 352, 4.10 gears will get you 10% more torque to the tires. Theres a "but", you will loose 10% in highway speed for the same rpm's and gas mileage will suffer. 3.73 looks perfect with just a camper, if you tow also then 4.10 would work better for a 352. A torque designed 390 or 410 would pull harder (alot more torque). What do you have, stick or auto? If it's a Cruise-O-Matic trans you will destroy it burning rubber, a C-6 is stronger, cheaper to rebuild and more common. A friend of mine just got his 67 back that had a wasted Cruise-O-Matic with alot of hard parts damage, total repair with labor, $1,750. Makes you want to "burn rubber". Done preaching. Carl.......o&o>.......
Old Dec 14, 2004 | 01:33 AM
trkdrvr's Avatar
trkdrvr
well the tranny was rebuilt in 2000 and i dont want too much torque. just want power when i step into it once in a while . the tranny is a automatic. there is no camper on it anymore. im just wanting to build a hot rod not sure what i have or if this is a good truck to do it with. i have it in the forsale ad area and also lookin for parts for it if i do not get rid of it. have pics too. thanks for the info.
gogoat
Dec 24, 2015 10:36 AM
gtotiger65
Aug 4, 2015 08:19 AM
COE Guy
Oct 20, 2012 09:39 PM
dyoungen
Feb 21, 2012 02:58 PM
dyoungen
Feb 20, 2012 09:49 PM
