Alarm wiring question.
Old Dec 12, 2004 | 10:21 PM
vfrrick's Avatar
vfrrick
Hello guys I have searched the forums and the net with no luck. I hope someone here can help.
Here it is. I have purchased a Option Group alarm Model LD 168-6C. Unfortunatly the install instructions are just a wiring diagram. I have got the power to the alarm and the keyless entry conected and the shock sensor installed. Now it wants me to connects a relay between the Ignition Key Switch and the Ignition coil. I don't know which wire I should be looking for on that one. I also need to connect the Head light system for warning and a Postive and Negative door switch. I assume the door switch is the interior lights. Two more connections one to the Foot brake I assume that is the brake light should be no problem. The last one is to the siren. The diagram only shows one wire to connect to the siren so I assume that the other wire from the siren I should just ground it.
I hope someone has a few answers for this because I don't want to have to guess at this one.
I am installing this on a 1999 F250 Super Duty.
Old Dec 13, 2004 | 12:49 AM
chiahunw's Avatar
chiahunw
Go to this website: http://bulldogsecurity.com/New%20Wir...rduty99-01.htm
This should be what you are looking for.
Old Dec 14, 2004 | 12:25 AM
vfrrick's Avatar
vfrrick
Ok guys I got everything going except three wires. If anyone has imput please don't hesitate.
I have one wire that is a Headlight on warning connection and the other two are door switch + and -.
whiteoak11
Aug 23, 2018 04:24 PM
xmontex4
Mar 25, 2018 03:08 PM
jforhan
Electrical Systems/Wiring
Sep 11, 2014 06:36 AM
fordtrucksj
Dec 11, 2012 06:39 PM
sami001
Jun 24, 2012 03:09 PM
