PLEASE HELP!!!!!!!!!!!!!!!!!
Old Dec 13, 2000 | 08:17 PM
AdamH's Avatar
AdamH
I am receiving error code 443 on my code scanner..."Purge Control Valve Stuck Open" I have a 96' 2.3L and my Chiltons manual does not mention this thing at all. Whare is this thing located? or whare can I get some guidance on changing it.
Thanks
AdamH
Old Dec 13, 2000 | 08:27 PM
jcheyn's Avatar
jcheyn
I don't know about the Ranger but my 1978 Ranchero has a purge control valve on the carbon charcoal canister. This is a plastic canister of charcoal that absorbs vapor from the carb float bowl. There is a valve on top of it that works off of vacuum from the carb and sucks the fumes into the canister. I wonder if your Ranger has a similar (but now electronic) setup.
Old Apr 6, 2001 | 10:27 AM
cubster's Avatar
cubster
i am unsure the exact location of it but follow vacuum hoses from egr. this valve is about the size of your gas cap and should have 2-3 wires to it. it is on top or visible not buried.if you are familiar w/ normal engine sounds you will be able to identify this. it cycles rapidly but not very loud.
Old Apr 6, 2001 | 11:08 AM
cubster's Avatar
cubster
