79 tilt column
Old Dec 12, 2004 | 08:19 PM
modrisco's Avatar
modrisco
79 tilt column
I am looking for a plastic cap which holds the lower bearing on the tilt steering column. Does anyone know where they are available? Also I have been looking in the past forum for the exploded view of this column, can anyone help find it.Thanks
Old Dec 12, 2004 | 10:41 PM
Mil1ion's Avatar
Mil1ion
These plastic pieces can be got from a Van with tilt.
Standard or tilt columns are the same when it comes to this part.
Old Dec 13, 2004 | 08:20 AM
mark a.'s Avatar
mark a.
Try L.M.C. or Auto Crafters
Old Dec 13, 2004 | 08:40 PM
modrisco's Avatar
modrisco
Thanks for the replies. However mil1ion I believe the van columns are different they have fixed metal bearing support and the nontilt columns I have seen have a different plastic end which also like the van doesn`t hold the bearing.
Mitch
Old Dec 13, 2004 | 10:10 PM
Mil1ion's Avatar
Mil1ion
I could probably find an old one but, have you checked here https://www.ford-trucks.com/advertise/advertisers.html ?
Old Dec 13, 2004 | 11:46 PM
hawkrod's Avatar
hawkrod
Mitch
Mil1ion is correct but with a caveat, I believe only 78/9 vans use the part. Also 4X4's without tilt have the same part and a few other applications as well. Hawkrod
Old Dec 14, 2004 | 05:32 PM
classyfish's Avatar
classyfish
I buy new ones when I rebuild the tilts I sell. I get them from Ford. A couple years ago you could pick em up for about 17 bucks. Last summer I bought 4 and they were 29 bucks a piece!!!!
Old Mar 15, 2005 | 10:14 PM
modrisco's Avatar
modrisco
79 Tilt column in a 77
Could some one please explain what modifications are required to use a tilt column from a 79 in a 77.
Thanks
Old Mar 16, 2005 | 09:37 AM
77460f150's Avatar
77460f150
I put a tilt in my 77 F-150 from a 79 Bronco and all I had to change was the steering shaft from the column to the steering gear box. The original shaft was 7/8" in diameter and the tilt needed to be 3/4" in diameter. When I called Borgeson to get a replacement shaft they told me Ford never made a 7/8" steering shaft. I have no idea what's up with that?? it had a stock automatic column in it that was factory I'm sure. So, I bought a new 3/4" anti vibration shaft from Borgeson and installed it all else hooked up and worked fine. -Ed
Old Mar 17, 2005 | 11:04 AM
pacochico's Avatar
pacochico
I have the same problem some months ago and i found the pice at the Ford dilership you have to take out the part so the can see it on ther computers but still avaleble.
Old Mar 17, 2005 | 12:30 PM
Father Ford's Avatar
Father Ford
Scored a perfect tilt column fron 78 F150 at the local Pull a Part today for $23.
Old Mar 17, 2005 | 02:47 PM
tellico racing's Avatar
tellico racing
That is a great deal. I sold 2 straight columns at a swap meet a couple years ago for $40 each.
Old Mar 17, 2005 | 09:31 PM
EBronco's Avatar
EBronco
Do you wish to sell it?
