Why is the bracket like this
That's a bracket for the upper radiator hose that routes around the serpentine belt and not through it. For PSD's with dual alternators. Ford just uses the same casting for all PSD's.
Most PSD owners go ahead and buy the wrap around hose to prevent having a mess on their hands if they just need to replace the belt.
Dual alternator hose, NAPA #9066.
I'm pretty sure, despite the high-amp "rating", using a truck alternator to supply current for welding would only result in a fried alternator. The only way I would attempt to power a welder from my diesel would be to use a power-take-off adaptor and run it to a real welding generator. Clumsy at best!
There are too many good gas-engine welders out there to fool with it.
Premier Power Welder
On the dual alt setup, the second alt is hooked up to the batteries for the rear box on ambulances etc. Its not tied into the primary electrical system. That would be cool for your trailer. Your trailer would have it's own Alt! Anyone know if there would be an issue with no load on the alt. when trailer is unhooked?
Hey, Kevin...
I want to do exactly what you wrote, supply power to the back on the second alternator. But I have a problem....
I just don't happen to have a second alternator. Shucks!
The idea is to let the second one charge a couple of golf cart batteries (12 volt of course) and run the fridge off the batteries.
What are the options and availabilities for obtaining a second alternator? Do I already have the bracket(s) and such?
2003 PSD 7.3L 4x4. auto trans.
Duncan
