high volume oil pump
Old Dec 12, 2004 | 12:46 AM
good 'ol ford's Avatar
good 'ol ford
ok guys what do u think about high volume oil pumps. going to have my motor out and was thinking of putting one on while i had it out. 77 351m stock oil pan. i know that some ppl say that it takes all the oil out of the pan but just wanted some other opinions
Old Dec 12, 2004 | 01:01 AM
Torque1st's Avatar
Torque1st
Posting Legend
Unless you have oil pressure problems do not install a HV pump. They are hard on cam gears and other drive parts.
Old Dec 13, 2004 | 09:22 AM
beartracks's Avatar
beartracks
Ditto..........
Old Dec 14, 2004 | 09:49 AM
mark a.'s Avatar
mark a.
I always run Sealed Power h.v. pumps with 20/50 oil and have never had a problem.
Old Dec 14, 2004 | 04:25 PM
OffOrWFO's Avatar
OffOrWFO
I have put over a 100k on a 400 with a HVHP pump and 10w-40. Haven't had any dist gear problems or any others for that matter. Has seen quite a few sub zero starts too.
Old Dec 15, 2004 | 01:54 AM
Torque1st's Avatar
Torque1st
Posting Legend
From what I have heard some of the cam makers will not warranty their cams if they are used with HV oil pumps. It only ads about 20-25% to the stress on the cam gears and drive so it should not be a problem but apparently some cam manufacturers think it is. I have heard of it taking out cam gears etc but I have not seen it myself. The stress would be greatest if you had a motor with tight or even good clearances and a HV pump resulting in high oil pressure all the time.
If you have tight or good clearances tho a HV pump is not needed, so why waste HP?
Old Dec 15, 2004 | 09:56 AM
beartracks's Avatar
beartracks
My stock blue printed pump makes 80 pounds cold and 50 warm running down the road. That's enough to worry me when it's cold as I have a roller cam. Use a hardened pump shaft.
