91 runing problems
Old Dec 11, 2004 | 09:17 PM
Nenzel's Avatar
Nenzel
91 runing problems
My truck is a 91 f150 4x4, I just bought it a while ago. When i drove it home from its previous owners, it ran like a champ. Then I went and tried the 4x4 in some mud, work really well! I went home and cleaned it, including powerwashing my motor. Now when i start it it runs good intill i feather the gas then it seems like it is going to die intill it revs up. I fixed it for a bit by spraying wd-40 on the electrical conections under the hood.
any suggestions would be appreciated.
dave
Old Dec 11, 2004 | 09:20 PM
MemOrex's Avatar
MemOrex
If it ran normal when you sprayed wd-40 under the hood, I would suspect a vacuum leak.
Old Dec 11, 2004 | 09:31 PM
Nenzel's Avatar
Nenzel
there is a vacum hose with a little bit of duct tape on it but i peeled it of an it was not cracked or not apparent holes, so i re taped it and forgot about it.
Old Dec 12, 2004 | 07:48 AM
EPNCSU2006's Avatar
EPNCSU2006
You need to go through all of the electrical connections and dry them out. It's not a good idea to pressure wash the engine with all the electronics on these newer engines. The connectors are sealed against water, but the high pressure forces the water by the seals and causes problems.
chadjones99
Dec 12, 2010 11:39 AM
mrbigmark
Jun 28, 2009 10:51 AM
andyfinck
Nov 9, 2006 07:34 PM
kens crewcab
Jun 8, 2004 04:27 PM
remmers
Dec 28, 2003 06:45 PM
