need help smokey psd
Old Jun 7, 2004 | 10:14 PM
kens crewcab's Avatar
kens crewcab
Unhappy need help smokey psd
i have a 1996 f350 psd with 317,569 miles . the poblem is when i start the truck in the morning it run on 7 cyls intill it gets warm and smokes like crazy till it gets warm, and the truck is now stumbling at 2000 rpm and smokes intill 2400 rpm it has a code in the computer idm fault can this be the problem or something else help me please
Old Jun 8, 2004 | 11:32 AM
78fordman's Avatar
78fordman
well, first off see what the fault is. As for the 7 cylender thing, sounds like it needs a set of glo-plugs. Is the engine ok until 2K rpm? sounds like low line pressure, when is the last time you changed the fuel filter? Your pump might be on its way also with 317K. See if you can go to autozone or somewhere and borrow a fuel pressure gauge and see what the pressure is and what it is supposed to be, sounds like glo-plugs and an injector pump. Whenever it change glo-plugs i change the glo-plug relay also, would not hurt anything.
Old Jun 8, 2004 | 04:27 PM
kens crewcab
thank you for the advice, the glow plugs are 2 months old and the feul filter is one week old did not check feul pressure will do that
dburch84f350
Jul 9, 2011 08:26 PM
tobacco farmer
Sep 17, 2008 07:14 AM
andyfinck
Nov 9, 2006 07:34 PM
chadjones99
Jan 8, 2006 09:22 PM
Lawemail
3.0L V6
Aug 15, 2005 10:32 AM
