Timing Question
Old Dec 11, 2004 | 10:56 AM
Doxy's Avatar
Doxy
Timing Question
I have a 1993 F-150 with a 302. I change the engine and the junk yard said the new 302 was the same year. The problem is the firing order is not the same, the book says that the 302 I got from the junk yard is 1995 or newer. Do I set the time to the 1993 specs? if not does anyone know the new setting?
Old Dec 16, 2004 | 07:45 AM
bob1987f's Avatar
bob1987f
the 95 motor uses the same firing order as a 5.0HO or a 351w.......even if you are using your trucks computer and distributor you need to change the firing order.
Old Dec 17, 2004 | 07:43 AM
F250SHELL's Avatar
F250SHELL
Timing Help
Thats Exactly Right. Its The Camshaft That Make The Difference. The Firing Order Is 1-3-7-2-6-5-4-8, And Base Timing Is 10 Degrees Btdc. Dont Forget To Unplug The Spout Connector Before Setting The Timing, Its The Little Gray Plug That Gives The Computer Control Of The Timing, Located By The Distributor Or Sometimes The Left Fenderwell.
Old Dec 17, 2004 | 09:07 AM
Doxy's Avatar
Doxy
Thanks. What about the computer? with the change in firing order will the comuter in the old truck work?
