Wire colors on 4 pin harness?
I am puuting some lights on my running boards, I want them to be on with the running lights and then flash too. I am splicing into my 4 pin trailer harness, then running a relay so that the lights are on with the headlights/running lights. Then when I hit the flashers the relay will break the ground to the running lights cauing them to shut off hence they flash. This will cause a wig/wag effect from the stock flashers hence being more visable and get someones attention. So I need to know what each color wire does on the four pin so I have right/right left/left and the running lights on. I know that that one is the brown/white wire.
Fire Rooster
Fire Rooster
Are you talking about the factory harness wire colors or the standard trailer wiring colors that you're likely to find on the trailer?
Std trailer colors:
white - ground
brown - tail/running lamps
yellow - left turn/brake
green - right turn/brake
On my truck's light harness:
brown/white - tralier running lamps
dark blue - electric brake control
red/yellow - trailer backup lamps
orange - trailer battery charge
dark green - right turn/brake
Std trailer colors:
white - ground
