360 to 351W?
Old Dec 10, 2004 | 01:45 PM
Jamie Miles's Avatar
Jamie Miles
360 to 351W?
I'm looking to replace the blown 360 in my 71 F250. One of my friend's dads has a 76 F150 with a low mileage 351W in it, but the tranny is blown. He wants 300 for the truck. I figgure I can buy the truck, drop the engine in my 71 and have the left over body parts (front fenders, hood, ect.) I have been needing for the 78 bronco I have been working on. Then I could sell what ever's left on eBay or somewhere and get at least half my money back, so it seems like a good deal any way you look at it.
Now I know my original C6 isn't gonna bolt up and I'm going to have to find another tranny, but other then that how hard would this swap be? What would I have to do as far as the engine mounts and stuff go?
I saw somewhere that the 351W shares the same bell housing bolt pattern as the 302? So would it be possible to use a T-5 tranny out of a Mustang? This truck will be a daily driver and I'm thinking the over drive would be a huge plus, but will it stand up to the 351's power?
Looks like I got my work cut out for me...
Thanks for any help.
Old Dec 10, 2004 | 05:04 PM
312's Avatar
312
just change the frame mounts and it will fit.the 302 and 300 have same bell as 351w.
Old Dec 10, 2004 | 05:55 PM
Ford Man 78's Avatar
Ford Man 78
The motor should drop right in the 76 mounts should be the same, as far as the T-5, it will hold up to the power but the output shaft on the T-5 I think is longer than the other ford standard transmissions and requires a spacer plate in between the bell housing and the trans. But check into that first I know the older 260, 289 needed that plate for the T-5 upgrade, if you could make it work somehow with the mustang cable clutch set up you could use the mustang T-5 bellhousing. Also make sure if you do go to a standard trans, you make sure the flywheel and front damper are from the same balancing 1980 they changed so don't use a early damper with a newer flywheel, it will cause a bad viabration and ruin your motor over time, good luck.
Old Dec 10, 2004 | 09:12 PM
85e150's Avatar
85e150
T-5 isn't rated for much over 300 ft lbs, be careful.
http://pages.prodigy.net/al.martin/T...d-T5-Data.html
Old Dec 11, 2004 | 01:14 PM
Jamie Miles
Exactly what I wanted to know.
Thanks!
Stephen67
Oct 28, 2009 07:34 AM
77FordDW
Engine Swaps
Nov 11, 2008 07:25 PM
1974F100
Aug 9, 2006 10:14 AM
Jamie Miles
Mar 17, 2005 11:50 PM
catdiesel
Nov 22, 2004 10:18 AM
