Edelbrock Shocks
Old Dec 10, 2004 | 06:27 AM
528bmw's Avatar
528bmw
Edelbrock Shocks
Anyone using?
What is life expectancy?
I have 45K on mine any they are running rough.
Thanks,
Old Dec 10, 2004 | 07:12 PM
NoMo's Avatar
NoMo
I thought they carried a lifetime warranty? Suggest you perform the appropriate tests to ensure they've failed then contact the manufacturer for replacement of the "bad" ones.
Old Dec 11, 2004 | 11:50 AM
ToolTime's Avatar
ToolTime
Talking
I recently installed Bilsteins front and rear, and the results are amazing! I do a fair amount of off-roading fast and slow, and I can say the Bilsteins are the best I have ever used hands down!
Old Dec 11, 2004 | 11:57 AM
tonum24's Avatar
tonum24
It's not the first time I've heard that. Get Koni's for the best ride and firmness, they're double tube shocks.
Old Dec 11, 2004 | 06:07 PM
ToolTime's Avatar
ToolTime
If you are anykind of off-roader, then you would know Bilsteins are the way to go! Now, that being said, I might use Koni's on a raod course car, (for racing), but would probably stick with Bilsteins...
Old Dec 15, 2004 | 07:13 PM
NorthCarolinaExpy's Avatar
NorthCarolinaExpy
XLT 2wd with air ride. . can a person install your Bilsteins all around with the existing air suspension? Rancho doesnt make a shock for the rears because of the air ride. thanks.
Old Dec 15, 2004 | 07:52 PM
xxx609's Avatar
xxx609
To "NCExpy", check out offroadwarehouse.com and walk thru their website. You'll find listings and mfg's part numbers for front/rear Bilstein shocks for 2wd and 4wd '97 thru '02 Expy's both with and without LLS.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
