I'M STUMPED! Little Help Please
Old Dec 9, 2004 | 10:28 PM
RyanRX7's Avatar
RyanRX7
I bought a van with a 302 Carb set-up and last week i installed a set of plugs and another carb. on the motor and it started right up i also found the plug wires cross in the wrong firing order.i thought i had the problem fixed but the motor would stall after a few minutes and got worse after putting back the hoses and air cleaner. I don't understand what the problem is, any ideas guys?
Old Dec 10, 2004 | 09:56 AM
Kemicalburns's Avatar
Kemicalburns
did you replace the cap and rotor? hows the timing? whats the mileage on the motor. you may also have a clogged fuel filter
Old Dec 10, 2004 | 11:27 AM
312's Avatar
312
what did it run like before you made changes.
