Expedition Trouble Code
Old Dec 9, 2004 | 07:23 PM
bchristal's Avatar
bchristal
Hello,
I have a 99 EB Expedition 111,000 miles. It runs fine, but I’m getting the following error codes:
<TABLE class=MsoTableGrid style="BORDER-RIGHT: medium none; BORDER-TOP: medium none; BORDER-LEFT: medium none; BORDER-BOTTOM: medium none; BORDER-COLLAPSE: collapse; mso-border-alt: solid windowtext .5pt; mso-yfti-tbllook: 480; mso-padding-alt: 0in 5.4pt 0in 5.4pt; mso-border-insideh: .5pt solid windowtext; mso-border-insidev: .5pt solid windowtext" cellSpacing=0 cellPadding=0 border=1><TBODY><TR style="mso-yfti-irow: 0"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; BACKGROUND: black; PADDING-BOTTOM: 0in; BORDER-LEFT: windowtext 1pt solid; WIDTH: 36.6pt; PADDING-TOP: 0in; BORDER-BOTTOM: windowtext 1pt solid; mso-border-alt: solid windowtext .5pt" vAlign=top width=49>Code
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; BACKGROUND: black; PADDING-BOTTOM: 0in; BORDER-LEFT: #e0dfe3; WIDTH: 3.9in; PADDING-TOP: 0in; BORDER-BOTTOM: windowtext 1pt solid; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=374>Definition
</TD></TR><TR style="mso-yfti-irow: 1"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0in; BORDER-LEFT: windowtext 1pt solid; WIDTH: 36.6pt; PADDING-TOP: 0in; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=49>402
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0in; BORDER-LEFT: #e0dfe3; WIDTH: 3.9in; PADDING-TOP: 0in; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=374>EGR Flow Excessive Detected
</TD></TR><TR style="mso-yfti-irow: 2"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0in; BORDER-LEFT: windowtext 1pt solid; WIDTH: 36.6pt; PADDING-TOP: 0in; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=49>181
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0in; BORDER-LEFT: #e0dfe3; WIDTH: 3.9in; PADDING-TOP: 0in; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=374>Fuel Temperature Sensor Performance
</TD></TR><TR style="mso-yfti-irow: 3"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0in; BORDER-LEFT: windowtext 1pt solid; WIDTH: 36.6pt; PADDING-TOP: 0in; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=49>7e5
</TD><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0in; BORDER-LEFT: #e0dfe3; WIDTH: 3.9in; PADDING-TOP: 0in; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=374>Not defined in my book
</TD></TR><TR style="mso-yfti-irow: 4; mso-yfti-lastrow: yes"><TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #e0dfe3; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0in; BORDER-LEFT: windowtext 1pt solid; WIDTH: 36.6pt; PADDING-TOP: 0in; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=49>E535
</TD></TR></TBODY></TABLE>
So I thought I was smart and I spent $77 at Autozone on a new EGR valve. Replaced it and I’m still getting the error code. Any ideas?
Thanks!
Brian
Old Dec 10, 2004 | 12:45 AM
Racerguy's Avatar
Racerguy
Hi Brian and welcome to FTE
To cure your P0402 you most likely need a new DPFE sensor. It's a small sensor that tells the PCM how much EGR is flowing. If you follow the EGR tube from the exhaust manifold up to the EGR valve you'll see 2 small tubes running off it. At the top of those tubes is the DPFE.
I would buy a genuine Ford one as it is "new and improved".
I've never seen a P0181. I would clear the code by removing a battery terminal for 10 minutes and then see if it comes back. If not then don't worry about it.
The other 2 codes you mentioned aren't normal codes. I have no idea what those are.
Old Dec 10, 2004 | 07:12 AM
bchristal's Avatar
bchristal
Thanks Dave!
I'll pickup a new DPFE sensor today.
Brian
Old Dec 10, 2004 | 03:46 PM
npearman's Avatar
npearman
it's definitely the DPFE sensor. It fixed the same code for me. I bought mine at autozone, but it's not called a dpfe sensor in their system. I think it was called egr valve flow sensor or something to that effect.
bismic
May 21, 2017 07:26 PM
bismic
Nov 23, 2016 07:43 AM
FTE/PARTS-GUY
Jan 16, 2009 10:30 AM
Meatco1
All Things Towing
Dec 27, 2008 10:01 AM
dougthorleyheaders
Vendor Specials, Discounts, Product Announcements & Group Buys
Oct 1, 2008 06:43 PM
