Offroad & 4x4
most changed truck
Old Dec 9, 2004 | 10:03 PM
ivanribic's Avatar
ivanribic
Upload them to your galler and then add before the address and after the picture address. It will make them appear in the tread
Old Dec 9, 2004 | 10:27 PM
highboy1975's Avatar
highboy1975
ok ill try and do that tomorow, it's still pretty dang ugly though.
Old Dec 10, 2004 | 06:21 AM
wyldstallyn73's Avatar
wyldstallyn73
A little off topic, but conained in this thread nontheless- In monsters beginning of this thread there is wording of "I will leave making polls up to Pro, he is so good at it" You mean to tell me nobody noticed that as an invitation to slam Pro a good one with the changing of one word!!!!!!! Ivan, I'm really dissapointed in you for missing that one- I dont feel I have been here long enough to have the right to jump on that!!!
Old Dec 10, 2004 | 02:51 PM
Stokes's Avatar
Stokes
in the beggining:
http://www.supermotors.org/getfile/6.../Clean_pic.JPG
then it got a 351w FI from a 91 F150
AOD whent through a major rebuild
Ate through two 8.8 rear axles
Leaf spring front convo along with a HP D60 completely rebuilt
Sterling 10.25 rebuilt
custom Drivelines
soon to be a BW1356 Tcase from a 88F350 with PTO hookup
soon to have new paint
and soon to be MAF via Cobra EEC along with a 70MAF meater and 24# injectors.
ruffly 6or so inches of lift useing all factory ford parts!
http://www.supermotors.org/getfile/1...tons%20040.jpg
i know there just 33s, but by early jan it will have 38.5 SX's
Old Dec 10, 2004 | 03:07 PM
Saurian's Avatar
Saurian
Got pics of my truck in my gallery now. Not much...compared to you guys.
Only changes so far are Exhaust and lighting...but tires are DEFINATELY going to get bigger. Gotta get lifted too though...
How the heck do I insert instead of link? It won't do it...
Old Dec 10, 2004 | 03:42 PM
teds74ford's Avatar
teds74ford
Here is what I started with:
imghttps://www.ford-trucks.com/user_gallery/displayimage.php?&photoid=43148&width=2/img
and here it is now
imghttps://www.ford-trucks.com/user_gallery/displayimage.php?&photoid=60143&width=2/img
I just tried this, and all I got was a h of stuff instead of a pic
Old Dec 10, 2004 | 06:14 PM
hockeyplurr's Avatar
hockeyplurr
Check out my gallery of before and after tell me what you think....
Old Dec 10, 2004 | 06:33 PM
79driver's Avatar
79driver
Check out my gallery. The Before pic was in November of last year. Wrecked in the front, bent frame, non running engine and bent front driveshaft.
Now it has a straight frame, some of the sheet metal back on the front, new brakes, good strong engine, and new driveshaft and soon to have 33's.
Old Dec 10, 2004 | 06:40 PM
Chris_ce's Avatar
Chris_ce
Can't figure the img thing out either so you will have to check my gallery. About all I got done was lift and tires plus a k&n fipk.
Old Dec 10, 2004 | 07:12 PM
Skipped_link's Avatar
Skipped_link
I don't know if I can enter more than one truck or not but here's my 03'
before,https://www.ford-trucks.com/user_gal...=43896&width=0
after,https://www.ford-trucks.com/user_gal...=43898&width=0
The lift & tires are obviouse but since the after picture the truck also got a turbo back hog exhuast system & superchips microtuner,
and then there is my 49' the seemingly never ending project
aprox, febuary of this year,https://www.ford-trucks.com/user_gal...=41405&width=0
actally I don't think the bed was that far along in febuary but either way
And this was about a month ago,https://www.ford-trucks.com/user_gal...=59746&width=0
Old Dec 11, 2004 | 12:02 AM
Stokes's Avatar
Stokes
and here it is now
I just tried this, and all I got was a bunch of stuff instead of a pic
fixed it for ya!
Old Dec 11, 2004 | 09:19 AM
monsterbaby's Avatar
monsterbaby
for those trying to figure out the posting pics another way to do it (and probably easier too) is go into your edit gallery page and under the pic you want posted you will see "Forum Codes" click on that, and a pop up type window will appear with 2 address links with the img tags already on them the top one should be for full size picture just copy, and paste into your post.
Old Dec 11, 2004 | 10:02 AM
  #28
Chris_ce's Avatar
Chris_ce
Well lets see if it works.
Before.
https://www.ford-trucks.com/user_gal...oid=48990&.jpg
After.
https://www.ford-trucks.com/user_gal...oid=52534&.jpg
First thing today I got right.
Old Dec 11, 2004 | 04:19 PM
  #29
rebocardo's Avatar
rebocardo
Personally, I would have liked to have started with Ivan's truck, but, I could not not find a 68-72 4x4 (2x4s are everywhere though) anything until I tripped across my truck going to a Home Depot. $850 and a $50 flatbed tow and it was mine.
My before pix when it had a bed and 33s, it looks nicer here, but, it had a bed that you would not put a bag of cement into it and no brakes etc etc.
Then a put a quick bed on it :
When the home made trailer hitch the PO welded on broke off when I dropped a 1200+ pound log on it from out of the bed (at was about 36"x60") I took the bed and the remains of the hitch off and put on the current bed.
Unfinished here, I added wood sides and such and have been using it for firewood and tree removal. I know the 31s probably look gay, but, the manual steering and 33s off road are a bit much in GA clay.
I reinforced the frame every 18 inches with 3/16 channel, did a 5x5x 3/16 sq.tube bumper, added air bags, a pintle hook, a tow receiver, in the bed winch, etc. I still have a piece of of 8x2x 3/16 to use as a push bumper for the front and a couple of pieces of 12x12x1/2 to use as winch mounts front and back.
It is ugly, but, functional, I bought it to work.
