World Class T-5
Check out these folks:
http://www.ttcautomotive.com/English/products/T-56.asp#Car
Also this guy works with TKO's:
http://www.4speedtoploaders.com/
More info here:
http://www.hanlonmotorsports.com/
Seller here, not much good to you in Al, but hey, support your local freight company:
http://63.246.5.93/?page=home/index&ps_session=c2f02b2d66c8a1d0cb42b5e74140d6c2
If you get one out of a Mustang at the scrappy, be sure to get the right one.
Go here for the chart. Watch out for those 4 cylinder jobs. You will be over the rated torque on a T5 out of a Mustang, so buy two or three:
http://pages.prodigy.net/al.martin/Transmission/Ford-T5-Data.html
Your engine is close to 400 lb-ft of torque, isn't it? Depending on how you drive and how heavy your rig is, you may or may not have good luck.
I'm thinking of putting one of these behind my 300 in my van as the grand canyon between 2nd and 3rd in mine makes for poor driveability in many circumstances.
The way I read these T 5 sites, you can bolt it right to your bell and your existing clutch will work as is.
Cross member and drive shaft is another question.
Good luck.
http://www.geocities.com/MotorCity/D...66/t5data.html
I know plenty of guys who put those trannys behind hot flatheads in fat fender rods with sticky rubber. Fall off the clutch once and BANG
If you have a decent rear ratio and dont need OD, a 60's 4sp toploader will be a rugged choice as they were built to go behind even the hottest FE's.
