Sponsored by: Real Truck
Advice please?
Old Dec 7, 2004 | 10:13 PM
wolfbike1500's Avatar
wolfbike1500
Advice please?
I own a 99 F350 lariat V-10 crew cab. I had an incident a few weeks back where I got a flashing OD off light on my shifter , indicating a transmission sensor alarm. It cleared after I turned the truck off and restarted. It has not recurred. I put a code reader on it today and got a code pending for the mass air flow sensor. This sensor is used by the transmission control module, but it seems odd that I would get a transmission error indication instead of a check engine light. All this being said, my question is, could there be any reason for that code other than a failing mass air flow sensor? Also if I need to replace the sensor, is there any brand that is recommended? The truck is completely stock, but I am not adverse to performance upgrades
Old Dec 8, 2004 | 03:01 PM
Hubs2000's Avatar
Hubs2000
Try disconnecting & reconnecting the battery. See if the pending code goes away.
