Oil pan
Old Dec 7, 2004 | 06:18 PM
yoda's Avatar
yoda
Oil pan
Sup guys I need a oil pan for a 2001+- F250 4X4 crewcab diesel(duh)
with a plow.I need a aftermarket oil pan that can be installed without unbolting
the engine thanks.
Old Dec 7, 2004 | 11:03 PM
Frobozz's Avatar
Frobozz
Well you're going to have to pull (or at least insanely raise) the engine to get the old one out, in any event... And short of some sort of dry sump system I'm not sure how you'd have a new one that doesn't work the same way.
Duncan
Old Dec 7, 2004 | 11:15 PM
Kwikkordead's Avatar
Kwikkordead
Is it rusted through and that's why you need a new one? You can patch it in the truck with a gas tank repair kit from NAPA.
Old Dec 8, 2004 | 12:03 AM
Ggg6's Avatar
Ggg6
Ford also sells a paint like coating that is used for repairing a rusted out oil pan.
You will need to pull the engine anyway to get the old one off. And to properly seal the new pan on. Believe me the block and pan must be sanitary before applying the special adhesive which has a set up time of like 48-72 hours.
