6.0 idling
Old Dec 8, 2004 | 01:59 PM
Bear Hunter's Avatar
Bear Hunter
Originally Posted by Customz
Mine sounds and acts the same when cold. This tank I have been trying a 5-10 minute warm-up and <2000rpm until mid-hash marks. My mpg should go way up due to the decreased idling time).
Do you have an aftermarket exhaust? and do you get it at the same RPMs?
Nice truck btw...the black on black is awesome.
Old Dec 8, 2004 | 06:31 PM
SBV45's Avatar
SBV45
Turbo drone is a very noticable low frequency vibration. It sounds sort of like the noise you get on a big block gasser with a big carb wide open. It only occurs at a very narrow range of rpms. It is caused by the engine firing and the turbo pedestal going into a vibration. It doesn't show up just at that rpm range, you have to be adding throttle. For me it was at 60 mph 1750 rpm and going up a slight incline. So as you add throttle to keep up speed/rpm, it starts the moan. First time it happened I sat upright and my wife said what is that?
Old Dec 8, 2004 | 06:50 PM
Bear Hunter
...appreciate it, thanks
Old Dec 8, 2004 | 08:06 PM
jjgi5150's Avatar
jjgi5150
Hi all,
My '04 with a 12/03 engine build date, with all original flashes, does the "up idle speed thing" after about a minute. It usually jumps to about 900-1000 rpms, then drops when I touch the brake or accelerator pedal....I have never let it idle more than about 5 minutes to see what it will eventually do??
I have noticed that it runs much smoother after a 5 minute idle warm up. Of course, it doesn't get too cold here in the So Cal desert, so I can't compare with all you cold climate owners. I still believe that all motors should have at least a 2-3 minute warm-up before any loads are put on them, if for nothing more than warming up the oil and getting it circulating well.
Take care all,
JJ
Old Dec 9, 2004 | 10:09 AM
04excursion_psd's Avatar
04excursion_psd
I got a new reflash and mine idles up to about 900 to 950 rpms when cold. It got around 25 here a few days ago. I usually let it warm up to the point when the temp gauge moves from the cold line as well. I also dont let it idle more than 5 or 10 minutes when warm, like if I am waiting for someone and when it is warm I start it and wait a minute or 2 then move out. This is my first diesel and just want to be a little carefull to do things right.
