1978 - 1996 Big Bronco
Overdrive not working?
Old Dec 6, 2004 | 05:57 AM
muckypaws's Avatar
muckypaws
Hi,
Is there any way to tell if the OD is working? I have noticed that the switch doesn't do anything when running at any speed so I guess there is a fault on the control system.
I note that the switch module comes out of the end of the transmission shifter as a complete module. Are these reliable as it would be a simple cheap thing to change first...
What is the typical failures on them.
'92 302 EB, E40D etc.
Old Dec 6, 2004 | 11:09 AM
Kemicalburns's Avatar
Kemicalburns
yes change out that module its more then likly your problem
Old Dec 8, 2004 | 12:53 PM
muckypaws's Avatar
muckypaws
I've had a look at this switch this eve and as far as I can tell its ok. I get continuity between two of the pins when the button is pressed and the LED lights up when I put a PP3 battery accros the correct terminals. I took the whole thing apart and cleaned up the internal contacts too as they were a little tarnished.
Where abouts is the PCM on a 92 Bronco with E40d so I can start chasing wiring.
Thanks
Old Dec 8, 2004 | 03:16 PM
Kemicalburns
im not sure where that is. but im sure someone will chim in soon
