Stuck Hood Latch. Help
Old Dec 5, 2004 | 09:29 PM
redneckf350's Avatar
redneckf350
Angry Stuck Hood Latch. Help
any advice on how to best remove the hood latch? any tips on getting the hood unstuck. any help would be greatly appreciated.
Old Dec 5, 2004 | 10:05 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Did the cable break? or is it just pulling real hard?
Old Dec 6, 2004 | 05:12 AM
trike1946's Avatar
trike1946
Try having someone pull the handle inside while you pull up on the hood.
Old Dec 6, 2004 | 05:56 AM
mistakenID's Avatar
mistakenID
Try pushing down on the front/center of the hood (right above the latch) while someone is pulling on the handle. That problem is pretty common if it's not a broken cable or latch.
Old Dec 6, 2004 | 08:40 AM
blu's Avatar
blu
I have a F250 that has this problem as well. Push down on the hood and with a long screw driver manually disengage the latch. After you get it open if you can't find the misalignment problem or adjust the cable you can knock off a little bit of the latch with a metal file--don't do to much. You should be able to see whats hanging it up. If you snapped the cable thats a different issue.
My issue resulted from the detent that keeps the hood from swinging to far open failed and the hood got "sprung".
Old Dec 6, 2004 | 05:25 PM
redneckf350
thanks for all the help had to stick my hands through the grill and take out the bolts that hold the latch something broke inside the latch and i broke the cable pulling on it off to the ford dealership since both parts are dealer only
ssandirene
WTB - Parts & other
May 12, 2015 09:37 AM
Redgranite_Yooper
Sep 7, 2014 09:59 PM
dferrell5
18
Aug 6, 2013 05:47 PM
pagoda69
Feb 27, 2013 01:03 AM
