Sponsored by: Kumho
quick question
Old Dec 5, 2004 | 08:12 PM
crack's Avatar
crack
quick question
with a stock motor....will switching from 33s to 36inch swampers somewhat decrease the preformance?..or will it help it preform better
im having an argument with someone about it
Old Dec 5, 2004 | 08:24 PM
ozzy460's Avatar
ozzy460
you will lose some performance.
Old Dec 5, 2004 | 08:26 PM
rakent's Avatar
rakent
You're increasing tire diameter (thus reducing your final drive ratio) and adding a significant amount of rotational mass.
If you're starting with a completely stock truck, more than likely than not performance will decrease noticeably.
Old Dec 5, 2004 | 08:33 PM
crack's Avatar
crack
ok, these people seem to think it will make no difference and that it could push 42s just as easily...in my mind it doesnt really work that way
Old Dec 5, 2004 | 08:59 PM
73Fastbackv10's Avatar
73Fastbackv10
If you increase your tire size, you'll have to get lower gears to compensate for them or else your boggers will do nothing buy bog you down.
Old Dec 5, 2004 | 09:54 PM
77hiboyboy's Avatar
77hiboyboy
not always, but when going to a very big tire(I think he mentioned 42's a re-gear would be a must, you are not only changing final drive, but your rotating mass, go weigh stock wheels, and then some 42's.
Old Dec 5, 2004 | 10:55 PM
crack's Avatar
crack
hmm were talking preformance in the mud and such right
Old Dec 5, 2004 | 11:50 PM
Hypoid's Avatar
Hypoid
Which motor are we talking about?
While the textbook answer is yes, with a longer stroke it's less noticeable.
When I put my 360 on the road (3.55 gearset), it could spin the 33's I had on the truck, on the highway it was still well enough into the torque band that it pushed them just fine at lower RPMs.
On the other hand, my clutch wasn't too happy with the treatment.
JMO, Mike
Old Dec 5, 2004 | 11:58 PM
crack's Avatar
crack
umm its this guys 94 ford f-150 so im guessing its a 302
Old Dec 6, 2004 | 12:20 AM
Hypoid's Avatar
Hypoid
Could be a Windsor also. Sounds like it's time to stop arguing and watch the results. A few upgrades later, projects like this take on a life of their own. Don't miss out on the fun.
For your own assurance, the motor's going to loose some mechanical advantage. That's the bottom line.
Mike
Old Dec 6, 2004 | 12:25 AM
crack's Avatar
crack
then we got into this argument about horsepower being needed to run the bigger tires and they were all no its torque blah blah gears..wich it is but I mean with a high hp motor you wopuld expect to have the torque and everything else to improve aswell so...I dunno ultimatley being a sock motor I think it would lose power....or whatever it would lose..if he put bigger tires on
