what is this worth
Old Dec 5, 2004 | 11:08 AM
f100guy's Avatar
f100guy
what is this worth
81 short wheel base f100 with a rebuilt 300 and a 3 spd. collumn shift tranny. it cranks right up and idles perfect. it is quiet and the body is in very good shape. it has a new battery,fuel pump and a few other things. the title is clear also. he wants 850 bucks for it, i think this is a good deal but my grandma does not. i am taking her to look at it today if she every gets back here. thanks to all. it does not have power brakes or power steering.
Old Dec 5, 2004 | 12:32 PM
69oiler's Avatar
69oiler
sounds like a good deal to me from your description. i had an '81 long bed F100 and i loved it. i sold it when i got my '86.
the only thing that may make it worth less to me is if it won't pass emissions.
Old Dec 5, 2004 | 12:36 PM
f100guy's Avatar
f100guy
emissions are no problem here, i had an 82 with no cats and 8 inch glasspacks. if this has a cat, i will be taking it off and putting my pollished banks muffler with pollished sidepipes
Old Dec 5, 2004 | 02:09 PM
86f15035s's Avatar
86f15035s
sounds like a good deal but why doesnt it have power brakes or power steering?
Old Dec 5, 2004 | 04:05 PM
Holmesuser01's Avatar
Holmesuser01
A company that I used to work for used to order Fords from the dealer that had clear glass, no radio, no power steering / brakes. The owner saves a fair amount of loot doing this. On the other hand, his trucks could haul due to the heavy duty suspension under the bed that he special ordered.
Old Dec 5, 2004 | 07:15 PM
f100guy's Avatar
f100guy
those were options in that year, not standard equipment. i drove it today and it drives perfect. hopefully nobody gets it while my grandma takes her time to decide.
Old Dec 5, 2004 | 08:32 PM
69oiler's Avatar
69oiler
seems to me it wouldn't be too hard to add power brakes, just swap in a booster/master cylinder and run a vac line to it. power steering i could probably live without on a shortbed 1/2 ton.
Old Dec 5, 2004 | 08:46 PM
f100guy's Avatar
f100guy
yes i have an 82 supercab body with power brakes and steering, i might put the power brake upgrade on this 81 but i won't mess with the PS. the brakes and sterring were not bad at all anyway so i might not do anything else to it
Old Dec 6, 2004 | 04:33 PM
69 and 85's Avatar
69 and 85
Sounds like a good deal to me.... plus if you wanted PB and/or PS just keep your eyes open. I bet you'll find someone would like you pull them off a parts vehicle for $50 or maybe less!
Old Dec 7, 2004 | 10:12 PM
f100guy's Avatar
f100guy
well i may be getting it within the next 2 days. i think it has a really high gear in the rearend. it takes a bit of gas and clutchwork to get it rolling at first.
Old Dec 8, 2004 | 01:33 AM
mustange70's Avatar
mustange70
Probably has the 2.45/3.00 rear gears, but that truck sounds like a really good deal, probably gets fairly decent milage too.
Old Dec 8, 2004 | 05:21 AM
locknkey's Avatar
locknkey
850.00 isn't a bad deal considering the cost of new trucks nowadays and the shape of some that I seen people wanting for much more in worst shape and condition. The fancy clutchwork problem could be it will be needing a pressure plate, clutch and throwout bearing soon so be aware of the costs for that.
