Give me $10 grand and I'll mod your engine.
Seriously I have a pic of my 10K http://www.ucsolutions.com/gregpictu...ggpictures.htm
It is a 10K ohm, 1/4-1/2 watt resistor used to fool the CPU into thinking it needs to raise the pressure of the high pressure oil. Which helps off the line performance a lot in some cases. Not so much in others.
