Transmission noises
Old Sep 5, 2001 | 03:51 PM
Goldilocks's Avatar
Goldilocks
Transmission noises
Has anyone experienced gear noise with late model Rangers with the 5spd manual? My 98 Ranger has a slight gear clash between 2nd to 3rd gear. I took it to the dealer last year
(20K miles ago) and they put in a new clutch, and rebuild the trans with a new ring gear and main shaft. A friend suspects that it isn't in the trans at all, but that the clutch isn't totally releasing when I put the pedal in and that the tolerances are tight enough inside the trans that going between 2 and 3 makes the gears catch a little bit. It doesn't do it all the time, just occasionally.
Ideas? Could the master cylinder for the clutch be weak and not supply enough pressure to the slave?
That's what my friend thinks, so is he full of it?
I am full and fed up with hearing the trans grind when I'm shifting.
Thanks.
Old Oct 17, 2001 | 11:03 AM
bline's Avatar
bline
Transmission noises
My 98 2.5L 5 speed does the same thing. I am not sure what the problem is. I have 75,000 miles on the truck now and other than that the transmission seems to be fine.
Old Oct 22, 2001 | 02:11 PM
79_1ton's Avatar
79_1ton
Transmission noises
it is more than likely the master cylinder. I would bleed it totally and fill it back up, is this the only gear that it happens on though?
Old Oct 22, 2001 | 02:21 PM
79_1ton's Avatar
79_1ton
Transmission noises
BW353
29
Dec 27, 2012 09:10 AM
gustang818
Jun 2, 2012 12:00 PM
chillin2nite2
Oct 13, 2008 03:21 PM
John LL
Jun 17, 2007 05:37 AM
Saoxcore2K5
Feb 2, 2005 10:43 AM
