99 flex fuel ranger code 122
Old Dec 4, 2004 | 09:54 PM
greta7's Avatar
greta7
code 122 on 3.0 automatic flex fuel ranger. low input switch A tps sensor. I have replaced tps twice and pigtail. Truck idles fine and runs great until under load. Loses power plus doesn't downshift under load . Need help, also what does switch A refer to?
Old Dec 4, 2004 | 11:48 PM
Rockledge's Avatar
Rockledge
Throttle Position Sensor Circuit P0122
Welcometo FTE!
The TPS sensor circuit is continously monitored (tested) by the PCM for a low throttle position rotation angle (voltage) input. If during Key On Engine Off (KOEO) or Key On Engine Running (KOER) the TP rotation angle (as measured in voltage) falls below a minimum calibrated limit (0.17 volts), the test fails. A P0122 trouble code is stored by the PCM and the CEL is illuminated.
Possible Causes:
- TPS not seated properly
- TPS circuit open to PCM
- VREF open to TPS
- TPS circuit short to GND
- Damaged TPS
- Damaged PCM
Tips for your '99 3.0L:
- GY/WH (Gray wire w/White Stripe) is the TPS circuit to the PCM
- BN/WH (Brown wire w/White Stripe) is VREF
- GY/RD (Gray wire w/ Red Stripe) is GND or SIG RTN
Keep in mind the KOEO voltage between VREF and GND should measure 4-6 volts, otherwise the circuit will be "underpowered" to start with.
HTH
Sean Wiles Sr.
Oct 22, 2012 10:18 AM
aa767man
Oct 4, 2011 09:34 AM
pmibach
1978 - 1996 Big Bronco
Oct 1, 2008 11:28 AM
agent007
Apr 25, 2007 04:30 PM
kfud
3.0L V6
Mar 16, 2004 06:01 AM
