Pressurized cooling system and Bad Pyrometer
Old Dec 4, 2004 | 09:48 PM
tdford's Avatar
tdford
Unhappy Pressurized cooling system and Bad Pyrometer
The pyrometer on my ATS turbo may be ok but while I was driving this week I noticed the reading seemed lower than usual. I jiggled the wire at the back of the gauge and the temp jumped 300 degrees and I'm very concerned. My turbo pressure only gets up to about 8 and I back off when temps hit 1000 but now I'm wondering if it may have been closer to 1300 degrees, maybe more and I've read in this forum that 1250 = damage. Now that we know my exhaust temps may have gotten too high does anyone have a better guess on why my cooling system pressurizes ( see the post "Pressurized Cooling System" Nov 30th) when the motor is cold but stops pressurizing as soon as the motor starts warming up? I also found about a quarter sized piece of very thin rubbery material under the radiator cap that could be gasket sealant. What are the indicators of heat damage that I should watch for as I pull the heads? The turbo still seems to have the same amount of boost (8) as always.
Old Dec 4, 2004 | 10:35 PM
PLC7.3's Avatar
PLC7.3
Just make sure when you pull the heads you undo the bolts in reverse torquing order 1/4 turn max at a time. Usually takes 2-3 times around the pattern. This helps eliminate head cracking on removal.
Old Dec 5, 2004 | 01:03 PM
motovert2001's Avatar
motovert2001
I have that same junk gauge,the thurmo wire is getting bad,good juck on finding one.I'll hope you have a head gasket problem and not a block or sleeve problem.
