ABS light
Old Dec 4, 2004 | 07:39 PM
brokentruck's Avatar
brokentruck
ABS light
My ABS light is on so I took my 97 Ranger to the ford dealer to have the error code read. They told me it is a code 12. My reservoir sensor is not working and I need a new reservoir. A mechanic friend assures me that the dealer is out to lunch and that if there is a problem with the reservoir sensor I will get a red light on the dashboard not an amber one.
Does anybody know these codes?
Old Dec 4, 2004 | 08:34 PM
Dave257's Avatar
Dave257
I would have to go with the dealer. According to ford a 12 DTC is "loss of Hydraulic brake fluid for one second or more during an anti-lock stop" and can be caused by:
1. low master cylinder fluid level.
2. fluid leaks in brake system.
3. Brake fluid level warning switch.
4. Master cylinder float.
5. diode/resistor elements.
6. Ignition switch circuitry.
7. anti-lock brake control module.
So it could be the reservior sensor.
Dave
Old Dec 8, 2004 | 12:12 PM
brokentruck
Thanks Dave, I am always skeptical when I can't talk with the ford mechanic directly. They have an intermediary sales guy that works on commision.
