ranger rotor replacement
Old Dec 4, 2004 | 05:12 PM
Johnny one's Avatar
Johnny one
1999 ranger 4x4 3.0 pickup. any help with replaceing the rotors. The Haynes repair manual is not very good for this replacement. Can the special tools that are needed for this job be bought on the internet.
Old Dec 4, 2004 | 05:16 PM
Rockledge's Avatar
Rockledge
What special tools? The front rotors on your 4x4 come off without removing the hubs, if that's what you're getting hung up on. Just remove the calipers and pull off the rotors, they slide off over the hubs.
Old Dec 4, 2004 | 06:15 PM
Higgin's Avatar
Higgin
Yes, it is a very simple job. I thought the haynes was plenty enough help to get it done (maybe you are looking at the pre-1998 directions in the haynes??). Took me about 45 minutes to replace front pads and rotors the first time i did it. Much more simple than i thought it would be. i belive the calipers are only on there with like 2 bolts. Just undo them and off the caliper comes, then just pull the rotor right off. Just make sure to have large C-clamp (i found it worked the best) ready to bottom out the caliper piston before you put on the new pads.
Old Dec 4, 2004 | 06:24 PM
Johnny one's Avatar
Johnny one
I did not pull the wheels yet, I was told by a friend that the 99 ranger with the pulse vacuum hubs, will have to be removed to get the rotor off, I have replaced many rotors in the past and they are fairly simple jobs as Rockledge and Higgin have stated I sure am glad to here the hubs do not have to be removed, thats where the special tools come in
glenT
Feb 14, 2014 12:58 PM
JSJOHNSON
Jan 11, 2011 11:55 PM
rnaydkirkpatrick
Sep 21, 2006 11:14 AM
ranger714
May 22, 2004 07:15 PM
JDC
Sep 28, 2003 12:31 PM
