what axle
Old Dec 4, 2004 | 10:01 AM
big_red_79's Avatar
big_red_79
Exclamation what axle
i am looking at buying yet another old ford...
i am trying to figure out what axle is in the front...
i cant go by year of the body cause the last owner custom fabbed some stuff... like super cab and a short box on a truck that had a regular cab and a long box so the frame is kina hacked up... but i am buying it for the 3/4 ton drive train... this also has the bendix type steering setup on the front. an 4 spd, dont know wich one, it has the divorced NP205 t case, and i know its a dana 60 rear. i just need to know what the front is. any help is apreciated
thanks
Old Dec 4, 2004 | 10:10 AM
highboy1975's Avatar
highboy1975
well, you dont tell us what year or gvw, so its most likely a d44. you need to post the front gvw so we can help you a little better.
Old Dec 12, 2004 | 09:20 AM
alans77crew's Avatar
alans77crew
Well what I'd do is to get my wire brush out and attack the axle tube next to the center section and clean them up there should be some #'s on it also on the center section it's self there was usually a id casting on it but first check and see if the tag is on the front cover it will tel you for certain. al
Old Dec 12, 2004 | 10:32 AM
Mil1ion's Avatar
Mil1ion
It's questions like this that are best asked in the Drivetrain Forum.
(Transmission,Rear ends,Transfer case,Clutch forum)
teamroper98
Dec 10, 2019 03:10 PM
chadandalysse
Sep 19, 2013 01:00 AM
cowboy_up_07
15
Jan 31, 2011 02:46 PM
Ron Kelley
Nov 2, 2007 10:40 PM
8 Lugs
Nov 25, 2005 09:15 AM
