Transfer Case ID
Old Dec 3, 2004 | 09:54 PM
Hotrodder's Avatar
Hotrodder
Transfer Case ID
I have a 74 ford F100 4x4 with a 360 and 4 speed manual trans. The transfer case only has 4 and 2, no 4hi 4low etc. Which case is this? Should i change to a different case? I hear a lot about np 205's, what makes them so special? Any help would be great.
Old Dec 3, 2004 | 10:22 PM
michaelbarry's Avatar
michaelbarry
the good thing about 205's is the durability...they're gear driven instead of chain driven...if put under pressure,chains can stretch...gears won't stretch...=)
Old Dec 4, 2004 | 02:04 AM
SoCalDesertRider's Avatar
SoCalDesertRider
That t-case with out the low range sounds like either a Dana 21 or 24 case (forget which). No need to change to another t-case unless you want one with the low range, in which case the NP205 would be the best choice to swap to. Your 4-speed trans should have a creeper first gear in it though, probably a Borg Warner T18 or NP435.
Old Dec 5, 2004 | 06:24 PM
Howdy's Avatar
Howdy
My 76 F100 had a 360, NP435 and a Spicer 21 TC. I never had a problem with the TC, but I did check on it and they are simple and cheap to rebuild.
F350mikey
Oct 9, 2019 01:32 PM
tommypic
Feb 24, 2009 09:56 AM
SoArkSI
Nov 5, 2005 08:43 PM
stepside64
Offroad & 4x4
Mar 6, 2004 12:40 AM
