'79 supercab; ignition timing???
Old Dec 3, 2004 | 03:10 PM
fordman77f1's Avatar
fordman77f1
i'm working on my '79 supercab. the engine is a 351m, i am trying to set the timing but i do not know what it is. the manual i have says to look for the sticker in the engine compartment for timing specs. its not there...does anyone know the timing specs???
thanks, mike
Old Dec 3, 2004 | 03:53 PM
hdgapeach's Avatar
hdgapeach
Most set the base timing at 10*BTDC. I usually warm the engine up and set mine with a vacuum guage to the highest amount of vacuum, then check with a timing light for reference and adjust carb settings. Remember to disconnect and plug the vacuum advance hose when setting base timing.
Old Dec 3, 2004 | 05:01 PM
F150daniel's Avatar
F150daniel
I turn it up till it spark knocks then back it off 2-3˚.
