Steering Slop
Old Dec 3, 2004 | 01:12 PM
Callcomm's Avatar
Callcomm
Steering Slop
I have a 2000 F-250 4X4 and have changed ball joints tie rod ends, Ilder arm and still have steering slop. Steering gear box is all that left. Who makes a good replacement box and power steering pump it's whinning. Thanks, Mike
Old Dec 3, 2004 | 05:50 PM
ALdieselfan's Avatar
ALdieselfan
Had the same issue with my 2000. Decided to adjust the box before replacing all the tie rods. It is like driving a new truck now. Will wait to replace tie rods. I am going to replace my pump. It has been whining and is getting louder.
Try adjusting your gear box before replacing.
Old Dec 8, 2004 | 11:22 AM
Callcomm's Avatar
Callcomm
Thank You. I will try that this weekend
Old Dec 8, 2004 | 11:43 AM
firemen122's Avatar
firemen122
I just adjusted my 97 193,000 miles only needed a little adjustment, man what a diffrence.....
Old Dec 8, 2004 | 03:45 PM
ChadT1980's Avatar
ChadT1980
how
how do u adjust it on a 2003 psd 4x4
Old Dec 8, 2004 | 08:11 PM
wingit1x's Avatar
wingit1x
How is this done? What type of characteristics do you obtain or correct?
Thanks!
Old Dec 10, 2004 | 12:08 PM
firemen122's Avatar
firemen122
check your tie rod ends for excessive play first,also check your steering shaft for play. If they are decent and you still have a lot of play in your steering wheel while driving, look on top of steering box you will see a nut with a screw in the middle of it. Losen nut and while holding nut still tighten screw half to 3/4 turn. snug nut check play. If you tighten to much steering box will bind, just back off screw a hair. when play is gone tighten nut good, may take you a few times adjusting to get just right....
Old Dec 11, 2004 | 06:04 PM
wingit1x's Avatar
wingit1x
Thanks for the info. I'll give this a try!
