new and need help
Old Dec 3, 2004 | 10:47 AM
relliott14's Avatar
relliott14
new and need help
gonna change injectors on '85 6.9 and I'm looking for a web site that will provide directions- thanks
Old Dec 3, 2004 | 11:11 AM
pnose's Avatar
pnose
Well you found it.What do you need to know?
Old Dec 3, 2004 | 12:39 PM
relliott14's Avatar
relliott14
thanks for the reply---need to know just about everything--looking for some written instuctions to review before I start--do I need any special tools?
Old Dec 3, 2004 | 02:33 PM
pnose's Avatar
pnose
No special tools needed.You will need a return line kit,it will have the new copper washers for the injectors as well as all new caps and o rings for the return lines.Remove injection line from the injector,remove the plastic caps from the top of the injectors.un-screw injector,screw in new injector torque to 35 ft/lbs.Make sure the old copper washer under the injector comes out,do not re-use it.While your in there it may be a good time to also check out the glo plugs.
Old Dec 3, 2004 | 05:26 PM
drivespline's Avatar
drivespline
Can you get to the injectors under the turbo on a 94 7.3 without removing the turbo?
Old Dec 3, 2004 | 05:29 PM
relliott14's Avatar
relliott14
thanks
thank you ---guess I have all I need--
