Sponsored by: Real Truck
Steering Clunking Noise!?
Old Dec 3, 2004 | 09:02 AM
Bigtruckdriva's Avatar
Bigtruckdriva
When I am driving straight Everything is Fine until i turn the wheel a little bit and I can hear a clunk and the floor at my feet makes a thud. It didn't do this until I put the lift on my truck! any suggestions as to what this noise/annoyance might be! Thanks A Bunch
BTD
99 250 5.4L 7.25" lift
Old Dec 3, 2004 | 02:17 PM
R1ZOOM's Avatar
R1ZOOM
Mine does the exact same thing, didn't start till I put my lift on, and mine does it going straight over big bumps. I retirqued everything once and it helped, but it's getting bad again. I have read on here to put a breaker bar on the trac bar bolt because an impact doesn't get it tight enough. I don't know, maybe someone who knows more can help. Try retorquing your shocks, u-bolts, and trac bar and see if it helps. Post a reply after you do.
Old Dec 5, 2004 | 10:09 AM
Bigtruckdriva
Bingo
I got under the truck last night and My adjustable trac bar was a little loose. So i turned it with my hand as tight as i could and re tightned it down. So far no problems. Thanks For the advice!!
Old Dec 6, 2004 | 04:11 PM
R1ZOOM's Avatar
R1ZOOM
good deal, maybe I'll climb under mine tonight and see if it's the culprit
