ECM does not communicate
Old Dec 2, 2004 | 08:14 PM
Tom G.'s Avatar
Tom G.
97, 7.3, was letting it warm up, rpm raised and lowered about 3 times and died. Hooked up diagnostics computer, does not communicate. Have constant 12 and switched 12 to ECM, ground circuit is OK, no power to IDM, no wait to start light. Checked for activating power at relay for IDM, 2.25 volt with key on? Is there an inline fusable link from the ECM to the relay panel? In the dark without and electrical schematic.
Old Dec 2, 2004 | 09:24 PM
01stroker's Avatar
01stroker
Tom, check the #22 fuse in the fuse box under the hood. I don't know if it is blown, if you would have voltage on the PCM, worth a look though. If it happens to be blown unhook the fuel heater element and replace fuse. CPS are bad to go out also.
Old Dec 4, 2004 | 05:45 AM
Tom G.'s Avatar
Tom G.
01stroker
#22 was blown, disconnected the filter heater and blew it again, disconnected the glow plug solenoid, blew again, now I am out of fuses but I know where to start now.
Thanks,
Tom G.
Old Dec 4, 2004 | 03:33 PM
01stroker's Avatar
01stroker
Tom, make sure you are unplugging the right plug. The water in fuel sensor is close by and maybe another one also. If you have any doubts take the fuel filter out and you can see which one is hooked to the element.
Old Dec 6, 2004 | 12:11 PM
Tom G.'s Avatar
Tom G.
01stroker,
That was it.
Thanks again
Tom G.
2002exPSD
Computer Chips & Tuners
Jun 26, 2022 05:13 PM
cavila06
28
Jun 7, 2013 11:03 PM
Chuck Fuller
19
Nov 27, 2012 03:56 PM
gaknut
Aug 13, 2004 05:16 PM
