engine surge
Old Dec 2, 2004 | 12:47 PM
yamaman's Avatar
yamaman
Unhappy engine surge
When the temp outside is cold the engine seems to surge even after the truck warms up? What could it be? it's a 99 powerstroke.
Old Dec 2, 2004 | 06:07 PM
1995Ford250's Avatar
1995Ford250
By surge, you mean it picks up idle, or it is running rough?
Old Dec 2, 2004 | 10:09 PM
Pikachu's Avatar
Pikachu
There was, if I remember, a TSB on this issue. I don't recal what the remedy was, however.
Old Dec 3, 2004 | 08:05 AM
3greenfordsagain's Avatar
3greenfordsagain
Mine does not surge but it bucks pretty good if you are holding a constant speed of 45-50 MPH. Could that be the CMP going bad?
Old Dec 3, 2004 | 09:06 AM
DavidHaile's Avatar
DavidHaile
My 2000 PSD X surges for 10-15 minutes after warmup when it is cold outside. I'm fairly positive it is the EBV oscillating. You can wire it open if you want - it is under or past the turbo, I believe. I just live with it because it does go away after a while and isn't hurting anything. I think its purpose is to prevent deposits on the exhaust valves after extended cold weather idling.
Old Dec 3, 2004 | 01:17 PM
yamaman's Avatar
yamaman
1995ford250, It feels like the foot feed is real touchy. I thougt it was me put it on cruz and seems the surge stops?
Old Dec 3, 2004 | 01:21 PM
3greenfordsagain
I have not tried to put on cruise to see if it stops. That might be a good test toward isolating the problem.
